Use of new GD 1.7.3
Brent Fraser
bfraser at geoanalytic.com
Mon Jan 3 20:50:15 EST 2000
Doug,
I did some experimenting with GD 1.7 some time ago. As
I recall, no code changes were necessary, as Steve had already
inserted the call to gdImagePng if the USE_GD_1_6 define
was set at compile time. Unfortunately, the mapserver executable
must be set up to use GIF OR PNG at compile time; it's not
switchable at runtime...
It did produce PNG images that looked like the GIF images.
My text was rotated 90 degrees, but I think that was an unrelated
problem.
Brent
----- Original Message -----
To: "Mapserver Users" <mapserver-users at lists.gis.umn.edu>
Sent: Monday, January 03, 2000 11:36 AM
Subject: Use of new GD 1.7.3
> I notice that the newest version of the GD library supports
> only PNG instead of GIF. If one uses it in lieu of an older
> GD library under mapserver, will it just make PNG automatically
> or do other configuration parameters need to be adjusted in
> mapserver for operation? I'm assuming that PNG would be adequate
> for most uses?
> Douglas D. Nebert
> Clearinghouse Coordinator
> FGDC Secretariat Phone: +1 703 648 4151 Fax: +1 703 648-5755
> Pager Messaging: http://fgdclearhs.er.usgs.gov/dougmsg.html
