Developing uniform mask
imap at chesapeake.net
Thu Jan 13 12:18:48 EST 2000
Steve,
I think Doug is using 3.2 Correct me if I am wrong here, but I dont think
INLINE FEATURES were in that version.
-Chris
Stephen Lime wrote:
> I might also add that you can use inline features to do this as well. No sense
> creating a shapefile in this case. Here's an example:
> LAYER
> NAME logo
> TYPE annotation
> STATUS DEFAULT
> TRANSFORM OFF
> CLASS
> TEXT " "
> SYMBOL 10
> COLOR 0 0 0
> END
> FEATURE
> POINTS 5 250 END
> END
> END
> Makes life a bit easier. Certainly easier to play with the placement.
> Steve
> >>> Doug Nebert <ddnebert at usgs.gov> 01/10/00 10:32AM >>>
> Trevor Banister wrote:
> > Just tell the layer not to transform.
> Thanks, that'll do it!
> > >From the docs:
> > transform [true|false]: Tells the MapServer whether or not a particular
> > layer needs to be transformed from some coordinate system to image
> > coordinates. Default is true. This allows you to create shapefiles in
> > image/graphics coordinates and therefore have features that will always
> > be displayed in the same location on every map. Ideal for placing logos
> > or text in maps. Remember that the graphics coordinate system has an
> > origin in the upper lefthand corner of the image, contrary to most map
> > coordinate systems.
> LAYER
> NAME logo
> TYPE annotation
> STATUS DEFAULT
> DATA "other/logo"
> TRANSFORM OFF
> CLASS
> TEXT " "
> SYMBOL 10
> COLOR 0 0 0
> END
> END
> > Mapserver community:
> > I am interested in creating a "template" or standard graphic method
> > that would be pasted into every delivered map from a given service
> > (i.e. from a given map settings file). At first I thought I'd just
> > make a GIF with a wld file, but then I realized that I'd need to
> > somehow compensate for its display at all scales, when it is actually
> > more a final mask to put on the delivered image than it is a layer
> > for the mapserver to deal with.
> > This kind of functionality would be helpful in letting someone add
> > a logo, graphic, some text, etc. to a map service to "personalize" it.
> > Can anyone think of a systematic means for accomplishing this?
> > Doug.
> > Douglas D. Nebert
> > Clearinghouse Coordinator
> > FGDC Secretariat Phone: +1 703 648 4151 Fax: +1 703 648-5755
> > Pager Messaging: http://fgdclearhs.er.usgs.gov/dougmsg.html
> Douglas D. Nebert
