loadWeb(): Unknown identifier
Jim T. Bowen (GAIA Consultants Inc.)
bowenj at gaiaenv.com
Thu Jan 20 19:21:27 EST 2000
I was receiving a similar error with some of my map files. It could be
a DOS-->UNIX issue. Try replacing the carriage return and line feed
combinations with a line feed only. But then again, a DOS-->UNIX type
error usually at an earlier line number. Might be worth a shot...
PS One software package that can perform this function in a DOS/Win
environment is UltraEdit
Michael Hass wrote:
> I am getting the following error when I try to run
> the 3.3.005 demo.
> loadWeb(): Unknown identifier. ( ):(23)
> My web object is below. Paths are same as a successful ini file.
> Does (23) indicate line? If so that would be the imagepath. My
> ms created gifs sit in the tmp dir.
> Mike
> WEB
> HEADER /home/k2rimap/ms_demo/demo_header.html
> TEMPLATE /home/httpd/html/krfrtf/demo.html
> MINSCALE 1000
> MAXSCALE 1550000
> IMAGEPATH "/home/httpd/html/images/tmp/"
> IMAGEURL "/images/tmp/"
> END
> M
_______________________________________
In order to reduce SPAM (i.e., junk
e-mail), all e-mail to me must include
the following somewhere in the body
of the message: J*I*M
Jim T. Bowen, M.Sc., President
Suite 306, 822-11th Ave. S.W.
Calgary, Alberta, Canada T2R 0E5
Ph: 403-571-7213 Fax: 403-571-7211
http://www.gaiaenv.com
