ArcView projection & mapserver projection
Stephen Lime
steve.lime at dnr.state.mn.us
Mon Jul 24 12:45:17 EDT 2000
If ArcView can handle it then I imagine Proj.4 can. Unfourtunately you'll have to
figure out the correct proj parameters on your own. The manuals help a bit but I've
found that some trial and error is necessary. The docs and most recent code are
at:
http://www.remotesensing.org/proj/
Good luck!
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> kibez <kibez at gilan.uar.net> 07/18/00 08:27PM >>>
I had problem with installation necessary proektsii for a map
In ArcView it is described so:
Projection: Transverse Mercator
Spheroid: Krasovsky
Central Meridian: 33.0
Reference Latitude: 0.0
Scale Factor: 1.0
False Easting: 6500.0
False Northing: 0.0
It is possible - whether to describe such projection a map-file???
PROJECTION
"PROJ = tmerk"
"ELLPS = krass"
END
