PHP Mapscript examples to add anotations to a map
    Carl Taylor
    cjtaylor at wcities.com
    Mon Jul 24 12:09:18 PDT 2000
The example below is very informative and I wondered if there are any
similar examples for PHP/Mapscript.  In particular I am using MySQL to hold
a large database of information and I would like to be able to annotate maps
with place names and notes regarding information from the DB.  I have tried
working through the Perl information but I have started to get myself
confused converting to PHP.
> The url below contains templates that change their behavior
> depending on the number
> of results found which is probably what you really want.
> http://terrasip.gis.umn.edu/cgi-bin/mapserv?map=/terrasipProjects/
tutorial/example5.map&layer=state_parks&layer=counties&layer=lakes
Thanks in advance for any advice people can supply,
Regards
Carl.
More information about the MapServer-users
