MapScript: Turn layers on/off
    Stephen Lime
    steve.lime at dnr.state.mn.us
    Mon Jul 24 19:47:09 PDT 2000
To turn a layer on you must explicitly set its status to ON. In perl the syntax is  $layer->{status} = $mapscript::MS_ON; then you can draw and so on.
And, yes you can create lauers using MapScript. See the example perl script in the new demo (in the  perl sub-directory) for an example.
Steve
>>> "Michael Anderson" <m_anderson14 at hotmail.com> 07/24/00 19:44 PM >>>
Hello,
I am trying to use MapScript to turn layers on and off and am having no
luck. I have a feeling the problem may be the order I an doing things, but I
have tried several combinations with no luck. Here is what I want to do
$map=new MapObj("anymap.map")
$img=$map->draw()
$layer=$map->getLayerByName("layerName")
$layer->draw($map,$img)
mapscript::msSaveImage($img,"image.gif",1,1)
I am using Python, not Perl, so there may be a few errors in the code. I
don't really know Perl. I have tried using prepareImage before making the
image, redoing the $map->draw()after turning the layer on, and a few other
combinations I can't remmeber now. Can someone set me straight?
Tomorrow I am plan to try to add layers to a map using MapScript. Is this
possible?
Thanks,
Mike
________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com
More information about the MapServer-users
