Funny units for jpeg images
John Hockaday
johnh at erin.gov.au
Mon Jul 31 18:58:21 EDT 2000
I am trying to get a jpeg to load as a background image with vector
data on top of it. Both are in geographical coodinates however, when I
load one on top of the other they seem to be in different projections.
The world file for the jpeg looks like this:
0.000450
0
0
-0.000450
150.000914
-33.998391
The image is supposed to be from TL(150, -34) to BR(151.5, -35). That
is 1.5 degrees by 1 degree with the top left corner at 150 degrees long
and -34 degrees lat.
Am I missing out on specifying a decimal degrees unit for my layers in
the map file? The map file is attached.
I would be greatfull for any information if someone else has used
georeferenced jpegs and vector shapefiles in a geographic coordinate
system.
Thanks in advance.
John Hockaday
# Start of map file
NAME DEMO
STATUS ON
SIZE 600 600
SHADESET /opt/contrib/src/ms_3.3.010/symbols/shade.sym
MARKERSET /opt/contrib/src/ms_3.3.010/symbols/marker.sym
LINESET /opt/contrib/src/ms_3.3.010/symbols/line.sym
EXTENT 149 -35 152 -32
UNITS dd
SHAPEPATH "/info/cgi-data/atlas/fornet/"
IMAGECOLOR 255 255 255
#LABELOVERLAP FALSE
# Start of web interface definition
WEB
#HEADER demo_header.html
TEMPLATE demo.html
#MINSCALE 1000
#MAXSCALE 1550000
END
# Start of reference map
#REFERENCE
#IMAGE graphics/reference_base.gif
#EXTENT 481093.000000 4969319.036682 502271.000000 4997508.3073184
#STATUS ON
#COLOR -1 -1 -1
#OUTLINECOLOR 255 0 0
#END
# Start of legend
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
# Start of scalebar
SCALEBAR
LABEL
COLOR 0 0 0
SIZE SMALL
END
SIZE 350 5
COLOR 255 255 255
BACKGROUNDCOLOR 0 0 0
OUTLINECOLOR 0 0 0
UNITS kilometers
INTERVALS 5
STATUS ON
END
# Start of layer definitions
LAYER
NAME coast
TYPE POLYGON
STATUS DEFAULT
DATA coast
CLASS
SYMBOL 0
OUTLINECOLOR 0 0 0
COLOR 248 248 95
END
END
LAYER
NAME si5609g
TYPE RASTER
STATUS ON
OFFSITE 0
END
LAYER
NAME cocos
TYPE RASTER
STATUS ON
DATA cocos.tif
OFFSITE 0
END
LAYER
NAME soils
TYPE POLYGON
STATUS ON
DATA soils
TOLERANCE 3
CLASSITEM "symbol"
CLASS
NAME "Classification by Symbol"
EXPRESSION "7"
COLOR 204 096 085
BACKGROUNDCOLOR 32 201 201
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "27"
COLOR 255 255 000
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "33"
COLOR 204 191 085
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "37"
COLOR 234 223 085
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "52"
COLOR 204 223 170
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "62"
COLOR 204 159 085
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "98"
COLOR 255 255 170
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "146"
COLOR 153 159 085
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "158"
COLOR 204 159 085
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "177"
COLOR 153 064 000
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "200"
COLOR 153 128 000
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "202"
COLOR 102 159 170
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "212"
COLOR 153 128 000
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "216"
COLOR 153 159 000
OUTLINECOLOR 0 0 0
END
#QUERYITEM symbol
QUERY
#EXPRESSION "216"
TEMPLATE demo.html
#JOIN "data/lakejoin.dbf" islake "type"
END
#QUERY
#EXPRESSION "^-"
#TEMPLATE land.html
#END
END # Layer
LAYER
NAME rne12030
TYPE POLYGON
STATUS ON
DATA rne12030
TOLERANCE 5
CLASS
NAME "rne12030"
COLOR 49 117 185
END
QUERY
TEMPLATE /info/cgi-data/atlas/fornet/rne12030.html
END
END # Layer
LAYER
NAME rail
TYPE LINE
STATUS ON
DATA rail
SYMBOLSCALE 4
CLASS
NAME "rail"
COLOR 212 212 212
SYMBOL 13
SIZE 2
MAXSIZE 4
END
QUERY
TEMPLATE /info/cgi-data/atlas/fornet/rail.html
END
END # Layer
#LAYER
# NAME primary_roads
# TYPE LINE
# STATUS OFF
# DATA primary
# SYMBOLSCALE 24000
# CLASS
# NAME "Primary Roads"
# COLOR 128 128 128
# SYMBOL 13
# SIZE 3
# MAXSIZE 5
# END
#END # Layer
#LAYER
# NAME runways
# TYPE LINE
# STATUS OFF
# DATA runways
# CLASS
# COLOR 30 94 30
# NAME "Airport Runways"
# END
#END # Layer
LAYER
NAME "points"
TYPE ANNOTATION
STATUS ON
MAXSCALE 6555555
DATA "points"
TOLERANCE 10
LABELITEM "Place_name"
CLASS
SIZE 8
COLOR 255 0 0
SYMBOL 6
LABEL
BACKGROUNDCOLOR 200 255 255
COLOR 30 94 94
TYPE BITMAP
#JUSTIFY CENTER
SIZE GIANT
POSITION AUTO
WRAP " "
END # Label
END # Class
QUERY
TEMPLATE /info/cgi-data/atlas/fornet/points.html
END # Query
END # Layer
END # Map File
