Query in Mapserver
Pericles S. Nacionales
pnaciona at gis.umn.edu
Tue Mar 21 21:50:28 EST 2000
The problem is you have the wrong syntax for JOIN. JOIN is now used in the
same way as other objects in a map file. That is you begin with the keyword
JOIN and end with END. Here's how it should look, based on the example you
gave:
QUERYITEM usclass
QUERY
EXPRESSION "421"
TEMPLATE lakes.html
JOIN # start of JOIN object
NAME water
TABLE "lakejoin.dbf"
FROM "islake"
TO "type"
TYPE single
END # end of JOIN object
END
QUERY
EXPRESSION "^-"
TEMPLATE land.html
NAME notwater
FROM "islake"
TO "type"
END
END # layer
Have a look at the map file docs (http://mapserver.gis.umn.edu/mapfile.html)
for other mapserver objects/keywords.
Perry N.
----- Original Message -----
To: <mapserver-users at lists>
Sent: Tuesday, March 21, 2000 5:23 PM
Subject: Query in Mapserver
> Hello,
> For 2 days I've been trying to run the demo query as follows:
> QUERYITEM usclass
> QUERY
> EXPRESSION "421"
> TEMPLATE lakes.html
> JOIN "data/lakejoin.dbf" islake "type"
> END
> QUERY
> EXPRESSION "^-"
> TEMPLATE land.html
> END
> END # Layer
> For some reasons, I always run into this error:
> loadJoin(): Unknown identifier. (data/lakejoin.dbf):(119)
> Could you help me in understanding the syntax for Mapserver query? I
really
> appreciate your help.
> Peter Le
