What's wrong with this mapfile?
Stephen Lime
steve.lime at dnr.state.mn.us
Mon Nov 6 10:47:06 EST 2000
Me thinks there is a memory error in 3.3.011 somewhere. It's rare but for
some reason it appears somewhat arbitrarily. Certain settings seems to cause
a problem, they're symptoms but not the cause. Would you be willing to
try your application against the nightly build?
Since you don't use any non-default symbols it should be an easy port. Just
strip out the symbol set lines and use the new version.
Much of the work on 3.3.012 has focused on tightening up the code and it's
probably the most stable version ever. (Perry could you post a 3.3.012 NT
binary as well? Call it nightly.zip.)
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> rgu at ems.muenchen.de 11/06/00 02:53AM >>>
Hello list,
I have a problem with the mapfile below:
It doesnt render until I either
* comment out the MAXSCALE in layer MSblock92
or
* comment out STATUS ON in the legend (resulting in no legend being
created)
or
* activate the fourth class "Nicht bewertet"
If one of these three conditions is met, the mapfile works like a charm.
I do have no explanation for this unlogical behavior and would be very
glad, if someone could point me out what's wrong with this map
definition.
Kind regards - Markus W. Spring
# MAPTITLE "Öffentliche Grünflächen und Wald"
# Start of map file
STATUS ON
SIZE 500 350
#SYMBOLSET "/data/web/ms_demo/symbols/symbol.sym"
SHADESET "/data/web/ms_demo/symbols/shade.sym"
MARKERSET "/data/web/ms_demo/symbols/marker.sym"
LINESET "/data/web/ms_demo/symbols/line.sym"
FONTSET "/data/web/ms_demo/symbols/fonts/fonts.list"
UNITS METERS
IMAGECOLOR 255 255 255
EXTENT 51199 23918 80829 46732
NAME k1_5_1
# Start of web interface definition
WEB
TEMPLATE /data/web/ms_demo/k1_5_1/k1_5_1.html
MINSCALE 2000.0
MAXSCALE 1550000.0
IMAGEPATH "/data/web/tmp/"
IMAGEURL "/tmp/"
END # WEB
# Start of legend
LEGEND
STATUS ON
LABEL
TYPE TRUETYPE
FONT arial
SIZE 10
END
END # legend
LAYER
NAME l24
DESCRIPTION "Gruenflaechen und Wald"
DATA /data/ua_shr/flaenutz/shapes/grwald
TYPE POLYGON
CLASSITEM "CODE"
CLASS
NAME "Wald"
EXPRESSION ([CODE] eq 1.00000000000000)
COLOR 1 100 0
OUTLINECOLOR 0 0 0
END # class
CLASS
NAME "Parks" # und Grünanlagen, Friedhöfe"
EXPRESSION ([CODE] eq 2.00000000000000)
COLOR 1 160 0
OUTLINECOLOR 0 0 0
END # class
CLASS
NAME "Kleingartenanlagen"
EXPRESSION ([CODE] eq 3.00000000000000)
COLOR 247 181 103
OUTLINECOLOR 0 0 0
END # class
# CLASS
# NAME "Nicht bewertet"
# EXPRESSION ([CODE] < 0)
# COLOR 255 255 255
# OUTLINECOLOR 0 0 0
# END # class
END # layer l24
# Background layer blockkarte
LAYER
NAME MSblock92
DESCRIPTION "Blockkarte"
# STATUS DEFAULT
TYPE Polygon
DATA /data/ua_shr/muc/shape/block92
MAXSCALE 50000.0
CLASSITEM "BLOCK92_"
CLASS
NAME "Baubloecke"
SYMBOL 0
COLOR -1 -1 -1
OUTLINECOLOR 165 165 165
END # class
END # layer MSblock92
END # map
