first steps and a basic question
A. Giacomelli
andreag at crs4.it
Mon Nov 20 05:21:10 EST 2000
hi all,
I have just started to work with the package, and walking the first
steps on the learning curve...
working from the tutorial, I have prepared a simple map file.
This gives no errors, but only generates a white (or IMAGECOLOR, anyway)
image.
NAME EX3
EXTENT 1409000 4294000 1505000 4577000
SIZE 300 400
SHAPEPATH "/opt/gislab/apache/htdocs/m2/data"
UNITS meters
WEB
TEMPLATE m2.html
IMAGEPATH "/opt/gislab/apache/htdocs/tmp/"
IMAGEURL "/tmp/"
END
LAYER
NAME "towns"
DATA towns
STATUS DEFAULT
TYPE POLYGON
CLASS
NAME "Towns"
COLOR 255 0 128
OUTLINECOLOR 0 0 0
END
END
END
for a cross-check, I have tried to use also another shapefile (with
geographic coords, using -180/180 -90/90 as extent), which displays
perfectly.
I would assume the problem with the first dataset has something to do
with the extent, but maybe I am missing some other basic issue...
TIA for any suggestions,
Regards,
Andrea
