Setting Paths
Kieran J. Ames
kames at keyspanenergy.com
Wed Nov 22 15:56:45 EST 2000
Thanks to all.
As I said in an earlier post, I'm just getting back into mapping. I copied all
my older stuff into an ms_demo directory and started from there.
That INCLUDED my old .map file which was missing IMAGEPATH and IMAGEURL. (It's
all so easy once you get the answers!)
Thanks again and have a good holiday!
Kieran
Brent Fraser wrote:
> You need to do two things:
> 1. set up a virtual directory, say g:\_PublicWebSite\wwwroot\ms_demo\tmp
> to point to g:\tmp (you've likely already done this)
> 2. Edit the demo.map file. In the WEB portion:
> IMAGEPATH "g:\_PublicWebSite\wwwroot\ms_demo\tmp\"
> IMAGEURL "/tmp/"
> Leave the demo.html as it was delivered.
> Brent
> bfraser at geoanalytic.com
> GeoAnalytic Inc.
> #300 , 700 - 4th Avenue SW Calgary, AB
> Canada T2P 3J4
> Tel: (403)213-2700 Fax: (403)213-2707
> www.geoanalytic.com
> ----- Original Message -----
> From: "Kieran J. Ames" <kames at keyspanenergy.com>
> To: <mapserver-users at lists.gis.umn.edu>
> Sent: Wednesday, November 22, 2000 11:00 AM
> Subject: Setting Paths
> > Group,
> > In getting the demo running, I'm running across some path issues that I
> > don't understand.
> > Running NT4.0 Mapserver 3.3.012
> > The Mapserv executable is in g:\_PublicWebSite\cgi-bin\mapserv
> > The demo is in g:\_PublicWebSite\wwwroot\ms_demo
> > The tmp directory (for images) is in g:\tmp. All directories have
> > appropriate read & write access and virtual directories are defined as
> > well.
> > The problem: the DEMO images are being written to
> > g:\_PublicWebSite\wwwroot\ms_demo and not to the tmp directory I thought
> > they'd be written to. I modified read and write access to get the page
> > to work. If I then change the pointer tags in demo.html from
> > SRC="[img]" to SRC="../../ms_demo/[img]"
> > then it all seems to work properly. However, that doesn't seem to be the
> > best way of doing things.
> > I understand that there is no longer a mapserv.ini file. How can I get
> > the files to write where I want them to?
> > Thanks for the help (and Happy Thanksgiving to all).
> > Kieran
