Mapserver <=> ArcIMS <=> MapXtreme, A similar question...
Paul Cameron
pcameron at gis.umn.edu
Sat Oct 28 13:20:27 EDT 2000
Hello,
I have something like this running on a soil survey application. Its quite
old now and I've been trying to find some time to port it to mapscript
where it will be easier to update the application. I create a popup window
that is the interface to the database. This form calls a perl script that
queries the database and writes a temp mapfile using the returned results
from the database. Its worked extremely well so far. The url is
http://gis.umn.edu/soils
paul
On Fri, 27 Oct 2000, Stephan Dunning wrote:
> But, the things I'm uncertain on are:
> * A SQL Query window allowing advanced queries to be run against our
> MSSQL Server DB, and then creating a temporary mapfile to display the
> results "on the fly"
> It sounds like this may be possible using perl, but I'm not
> positive. Maybe javascript, java, VB, etc. could accomplish these things?
> Stephan
