[mapserver-users] XML interface for query templates
Cameron Shorter
cameron at socialchange.net.au
Sun Apr 22 19:45:08 EDT 2001
We are playing around with a perl wrapper for mapserv which will provide
a GML interface to mapserv.
However, we have run into a problem with queries. Query responses need
to be returned in XML format. Some the the .dbf files we have contain
">" chars which needs to be converted to ">" if it used in an XML
response. Currently, this option does not seem to be available in
mapserv.
So, what I'd like to add to the query object is an option like:
* xml_conversion [true|false] which defaults to false
When xml_conversion=true, data from the .dbf columns will be converted
to be xml compliant.
If this is OK by mapserv architects and our clients, then we will go
ahead and implement it.
The logic required would be something like the following (example in
perl)
# Make the strings XML compliant:
for (@_) {
s/\&/&/g;
s/\</</g;
s/\>/>/g;
# strip quotes if they are at wrapped around a term but
don't
# remove them if they are in the middle of a term.
# Ie, "Towns" = Towns
# Town's = Town's
s/^\'(.*)\'$/$1/;
s/^\"(.*)\"$/$1/;
s/\'/'/g;
s/\"/"/g;
The extra parameter would need to be inserted in maplexer.l
My guess is that the xml conversion would need to be inserted in
mapserv.c somewhere near line 1277:
for(i=0;i<Query->numitems;i++) {
sprintf(substr, "[%s]", Query->items[i]);
if(strstr(outstr, substr) != NULL) { /* do substitution */
outstr = gsub(outstr, substr, Query->data[i]);
} /* next item */
Cameron Shorter Web Mapping Manager
Social Change Online
248 Johnson St Tel: +61 (0) 2 9692 5115
Annandale NSW 2038 Fax: +61 (0) 2 9692 5192
Sydney, Australia http://webmap.socialchange.net.au
