[mapserver-users] XML interface for query templates
Cameron Shorter
cameron at socialchange.net.au
Mon Apr 23 17:51:33 EDT 2001
Comments inline.
Stephen Lime wrote:
> Hi Cameron: We're also working on XML output, initially as part of WMS compliance
> but then in a more general sense.
Ah yes, we are creating a WMS (web map server) by putting a perl wrapper
on top of mapserv. (We have it working with a couple of minor bugs).
It would be great to see it done properly within the mapserv baseline.
How long to you expect it to take to develop the WMS interface?
> I do see the need to allow XML (and even just HTML)
> output as part of general template usage. I assume that's where you're running into
> trouble.
Yes.
> If you're accessing the features directly in perl and producing the XML from
> within the scripts (eg. not using templates) then it's easy enough to do the substitution
> in perl. Here's what I propose:
> 3.5 already allows you to change DBF item filtering in templates so you can request
> an item called NAME using [NAME] or [NAME_esc]. The first gets you the straight
> string, the second gets you the string escaped for inclusion in a GET request. It would
> be easy to add a third option [NAME_xml] or similar that would XML escaped equivilalent.
Yes, that would do the job.
> If you could come up with the function to do the XML escaping, it's got to already
> exist someplace, then I could add this to 3.5 (which is really pretty stable) in a few minutes.
I will search around today (overnight for you people in the USA).
Cameron Shorter Web Mapping Manager
Social Change Online
248 Johnson St Tel: +61 (0) 2 9692 5115
Annandale NSW 2038 Fax: +61 (0) 2 9692 5192
Sydney, Australia http://webmap.socialchange.net.au
