[mapserver-users] Multiple LabelItems from dropdown?
Puneet Kishor
pkishor at GeoAnalytics.com
Fri Aug 3 13:58:59 EDT 2001
Hi Mark,
The quickest way that come to my mind is...
make a separate layer for each of the labels... that is, one airport layer
with airport name as labelitem, another airport layer with faa id as label.
Turn the status to off for all of them.
then use the form to grab the labelitem and turn that specific layer on by
setting its status to on.
hth.
pk/
Puneet Kishor
pkishor at geoanalytics.com
www.geoanalytics.com
GeoAnalyics, Inc.
1716 Fordem Ave
Madison WI 53704
-----Original Message-----
From: Mark Abernathy [mailto:WMABERN at gwm.sc.edu]
Sent: Friday, August 03, 2001 11:12 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [mapserver-users] Multiple LabelItems from dropdown?
Hi folks,
I have an airport layer with different classes of airports within it
determined by a SYMBOL attribute in the shape file. I would like to be able
to choose the Attribute to display at run time by feeding the labelitem i.e
FAAID or Airport Name from a dropdown list box on my html form.
In other words, I want the user to be able to diplay the Airport name if
they want, or the FAA Id, etc... chosen from a dropdown. Can this be done?
I haven't seen a question on this or an example of this in the archives.
Does anyone have an example of doing this and what variable should I be
passing to the map file and what is the syntax of that, please? Also, any
suggestions on the coding of the html drop down? Thanks for any assistance.
Below is a snip of my map file.
# Start of AIRPORT Layer
LAYER
NAME AIRPORT
TYPE Point
DATA AIRPORT
STATUS DEFAULT
LABELITEM FAAID
CLASSITEM "SYMBOL"
CLASS
EXPRESSION /1/
NAME "Public Airport"
SYMBOL 13
SIZE 11 # legend symbol size
COLOR 102 204 000 # legend symbol color - green
LABEL
COLOR 0 0 0
OUTLINECOLOR 255 255 153
POSITION AUTO
SIZE small
PARTIALS TRUE
BUFFER 2
END
END # CLASS
