[mapserver-users] Compilation/ESRI SHapeLIB
Daniel Morissette
morissette at dmsolutions.ca
Tue Aug 7 12:01:12 EDT 2001
Stephen Lime wrote:
> The mapserver binary can't find the shared libs it needs. The easiest way to
> fix this is to use the Apache directive SetEnv to set an environment variable
> called LD_LIBRARY_PATH. Add something like:
> SetEnv LD_LIBRARY_PATH /lib:/usr/lib:/usr/local/lib:..other dirs with shared libraries...
> to httpd.conf and restart.
See also
http://www2.dmsolutions.ca/mapserver/php_mapscript/php_mapscript_faq.html#4.2
It's about PHP MapScript but it applies to your case as well.
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
