[mapserver-users] queryUsingPoint seg fault on demo maps
Jim Burnett
jimburnett at ntelos.net
Tue Aug 7 17:08:06 EDT 2001
OK, I switched to GD1.8.4 and MapServer/Script 3.5 (nightly build)
Instead of a complete crash, I get this. ( better then complete crash)
Warning: MapServer Error in msQueryByPoint(): No matching record(s) found.
in /drives/storage1/homes/htdocs/maptest/php/test.php on line 71
here is my code:
I am using the shape file and map file provided in the demo, i just renamed
it.
if ( $map_x && $map_y ) {
$mapObj = ms_newMapObj("/home/htdocs/maptest/romney.map");
$ptClicked = ms_newPointObj();
$ptClicked->setXY($x,$y);
print $ptClicked . "<br>\n";
#$layerObj = $mapObj->getLayerByName("lakes");
$queryObj = $mapObj->queryByPoint( $ptClicked,MS_MULTIPLE,-1 );
#$qObj = ms_newQueryObj($layerObj);
#$qObj->setexpression("/./");
#$queryObj = $layerObj->queryByPoint( $ptClicked,MS_MULTIPLE,3 );
print "click X Y:" . $map_x . " x " . $map_y . "<br>\n";
print "mapObj->name:" . $mapObj->name . "<br>\n";
print "mapObj->numlayers:" . $mapObj->numlayers . "<br>\n";
print "layerObj->numqueries:" . $layerObj->numqueries . "<br>\n";
print "layerObj->other:" . $layerObj->queryitem . "<br>\n";
print "queryObj->numresults:" . $queryObj->numresults . "<br>\n";
print "queryObj:" . $queryObj . "<br>\n";
----- Original Message -----
From: "Daniel Morissette" <morissette at dmsolutions.ca>
To: "Jim Burnett" <jimburnett at ntelos.net>
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Tuesday, August 07, 2001 4:28 PM
Subject: Re: [mapserver-users] queryUsingPoint seg fault on demo maps
> > Jim Burnett wrote:
> > I get a segfault when try to do a queryUsingPoint...I am testing with
> > the demo maps....My map browsing works like zooming and panning, but
> > now I want to query the map data when I click on an area, and return
> > data from the attribute data. Like the area of the lake and miles and
> > stuff.
> Jim,
> Seems like you're running MapScript 3.4 with PHP 4.0.6 ... this
> combination is known to have a problem which is documented at the
> following URL:
http://www2.dmsolutions.ca/mapserver/php_mapscript/php_mapscript_faq.html#4.
5
> You'll have to either switch to MapServer 3.5 or backtrack to PHP 4.0.5.
> The following message in the archive also tells you how to patch your
> MapScript 3.4 if you really can't switch versions of PHP or MapServer:
http://mapserver.gis.umn.edu/majordom_lists/archives/mapserver-users/html/01
07/msg00204.html
> Daniel Morissette morissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
> Don't put for tomorrow what you can do today, because if
> you enjoy it today you can do it again tomorrow.
