[mapserver-users] Compilation/ESRI SHapeLIB
Richard Ford
mapserver at cubok.com
Wed Aug 8 01:54:51 EDT 2001
G'Day All,
I did the ldconfig thing. And it works.
Funny thing is though, when I compiled PROJ with
a --prefix=/usr/local/projlib and compiled map server against that
directory. And added /usr/local/projlib to ld.so.conf and ran ldconfig,
mapserver would still fail in the same way.
However doing a straight ./configure of proj so that it would install to
/usr/local/lib and adding that to ld.so.conf, mapserver did work?
Strange?
Richard.
----- Original Message -----
To: "Richard Ford" <mapserver at cubok.com>
Cc: "Map" <mapserver-users at lists.gis.umn.edu>
Sent: Wednesday, August 08, 2001 2:12 AM
Subject: Re: [mapserver-users] Compilation/ESRI SHapeLIB
> > mapserv: error while loading shared libraries: libproj.so.0: cannot load
> > shared object file: No such file or directory
> > [Tue Aug 7 15:19:45 2001] [error] [client 192.168.188.1] Premature end
of
> > script headers: /usr/local/apache/cgi-bin/mapserv
of
> > I take it that the libraries can't be found or loaded? With PROJ
disabled
> > the mapserv runs fine.
> > So why or what is wrong? :)
> Maybe you need to add the directory where libproj is to /etc/ld.conf and
> run ldconfig afterwards.
> V. <v at w.cl>
