[mapserver-users] PHP ZoomPoint
ANDREW WOOLEY
AWOOLEY at mountainland.org
Fri Aug 10 12:10:52 EDT 2001
Thanks to everyone who replied and offered their help. This list rocks.
This is the correct answer: For my rect extent, I changed the maxy and the miny and it worked as advertised. Thanks very much for the assistance.
Daniel, is this a bug or is it just my stupidity? It seems more likely to be the latter. Thanks again.
Andrew
Andrew Wooley
GIS Operations Manager
Mountainland Association of Governments
Orem, UT
phone: 801.229.3844
fax: 801.229.3801
email: awooley at mountainland.org
>>> Daniel Morissette <morissette at dmsolutions.ca> 08/10 8:34 AM >>>
ANDREW WOOLEY wrote:
> When I echo the extent minx, etc. it gives reasonable coordinates for the map extent (1800193, 825044, 2115496, 542882), however, after this code executes and I echo the new extent, I get good values for some of the coordinates but not others (1877442.235, -78702.92, 2035093.735, 78702.92). Can someone explain to me what I am doing wrong and why the negative values show up? Thanks.
You wrote that your original extents were:
I notice that YMin > YMax ... maybe that confused the ZoomPoint()
function... try again with YMin < YMax ... and if it works this time
then please file a bug in the MapServer bugzilla about this and we'll
fix ZoomPoint() to deal with this properly.
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
