[mapserver-users] extents/coords questions
Daniel Morissette
morissette at dmsolutions.ca
Fri Aug 17 08:59:17 EDT 2001
Hi Drew,
Drew wrote:
> 1. What's the best way to get the extents of my map, I have 1000's of tiles
> in a directory, and also a tileindex file. My current extents appear to be
> off, as the bounding box on my reference map is way off.
Running OGRINFO on the tileindex file would return you the extent of the
tileindex which is also the extent of all your files.
> 2. How do I plot things on my map based on a list of 100 or so coordinates?
> I'm not sure if there is any coordinate data in my shapefiles, and if there
> is, what format it is in. How do I find out? Do I need to?
Again, try OGRINFO to dump the contents of the shapefile and you'll see
if it's a point, line or polygon file and then you can set your map
layer accordingly.
See the OGR-HOWTO on the MapServer website for examples using OGRINFO.
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
