[mapserver-users] 3.5 compilation problems.
Stephen Lime
steve.lime at dnr.state.mn.us
Thu Aug 23 11:26:16 EDT 2001
GD 1.2 is not supported any more. I suspect it doesn't contain the missing
function noted below and hence the error.
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Marcus Dillury <md at socialchange.net> 08/22/01 09:32PM >>>
I am trying to compile a 3.5 build of mapserver on a Redhat 7 Linux box.
I am using the following options with the configuration script.
./configure --with-proj=/usr/local --with-gdal --with-gd=/usr/local/lib/gd-1.2 --with-freetype=/usr/lib
proj-4.4.3
gdal-1.1.5
gd-1.2
freetype-1.3.1-7
The Makefile builds without complaint.
When I run 'make' I get the following problem
gcc -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
-DUSE_PROJ_API_H -DUSE_WMS -DUSE_TIFF -DUSE_JPEG -DUSE_GD_GIF
-DUSE_GD_SWAP_XY -DUSE_GDAL -I/usr/local/lib/gd-1.2
-I/usr/local/include -I/usr/local/include shp2img.o -L. -lmap
-L/usr/local/lib/gd-1.2 -lgd -ljpeg -L/usr/lib -lttf -lpng -lz -ltiff
-ljpeg -L/usr/lib -lttf -lpng -lz -L/usr/local/lib -lproj -ljpeg
-L/usr/local/lib -lgdal.1.1 -lm -o shp2img
./libmap.a(mapresample.o): In function `msResampleGDALToMap':
mapresample.o(.text+0xe8e): undefined reference to `gdImagePaletteCopy'
mapresample.o(.text+0xec4): undefined reference to `gdImagePaletteCopy'
collect2: ld returned 1 exit status
make: *** [shp2img] Error 1
Does anyone seen this error before? Could I please get some pointers or
advice?
Thanks in advance,
--Marcus
