[mapserver-users] basic search question
Brian Fischer bfischer at mpls.houstoneng.com
Thu Aug 23 12:02:21 PDT 2001
Basically you have to add a mapextent to the URL, couple of different
options to construct the map extent.
1.)	&mapxy=[shpmid]&buffer=5000
2.)	&mapext=[shpext]
3.)	&mapext=[shpminx]+[shpminy]+[shpmaxx]+[shpmaxy]
-brian
-----Original Message-----
From: Jim Burnett [mailto:jimburnett at ntelos.net]
Sent: Thursday, August 23, 2001 12:41 PM
To: kenboss; mapserver-users at lists.gis.umn.edu
Subject: Re: [mapserver-users] basic search question
ok, if I want to display just 1 item, say a parcel.....how would I blow
it
up to full extent?
This is what is working, I can search my sql database by person's name
and
get the parcel_id. I can also show on the map were the parcel is using
the
code below.
Now I want to make that little parcel, blow up full screen. Do I have to
set
extents?
-jim
----- Original Message -----
From: "kenboss" <kenboss at dilbert.dnr.state.mn.us>
To: <mapserver-users at lists.gis.umn.edu>; <jimburnett at ntelos.net>
Sent: Thursday, August 23, 2001 10:56 AM
> It's been a while, but I'll take a shot.  I can think of a couple of
ways
to get there.
> If you have x,y coordinates for the centers of your parcels in your
mysql
database, you can just run
> your search, grab the results, and redirect to a url like:
http://myserver.com/cgi-bin/mapserver?map=parcel.map&mapxy=x_from_mysql+
y_fr
om_mysql&scale=150000
> If you have a common unique parcel ID in both the mysql database and
the
parcels shapefile, you can
> grab that ID from your search and then redirect to something like:
http://myserver.com/cgi-bin/mapserver?map=parcel.map&qlayer=parcels&mode
=ite
mquery&item=parcelID&value
> =unique_ID_from_mysql
> In turn, in your mapfile your parcels layer would have a query
template
like:
> http://myserver.com/cgi-bin/mapserver?map=parcel.map&mapext=[shpext]
> to display the map.
> At least, that's how I'd approach it from ms_3.3.  I understand
itemquery
has changed in 3.5, and
> there may be better ways to get there.
> Hope this helps,
> --Ken Boss
>   MN DNR Forestry Resource Assessment
> > From: "Jim Burnett" <jimburnett at ntelos.net>
> > Subject: [mapserver-users] basic search question
> > Date: Thu, 23 Aug 2001 08:44:19 -0400
> > MIME-Version: 1.0
> > X-Priority: 3
> > X-MSMail-Priority: Normal
> > X-MimeOLE: Produced By Microsoft MimeOLE V5.50.4522.1200
> > Can I do a seach on my standard database(mysql) for an address, and
then
pop up the parcel(map)
> based on my search?
> > So, can I create a map, based on search results?
> > I know I can click in the map, and query were I am clicking, but I
want
to do the opposite, and do a
> search, then display the map....
> > -jim
More information about the MapServer-users mailing list
