[mapserver-users] Simple QUERY problem (fwd)
Stephen Lime
steve.lime at dnr.state.mn.us
Tue Aug 28 09:24:41 EDT 2001
Actually, header and footer are valid at the layer level as well. All layer results are wrapped
by those files with ALL results wrapped by the header and footer in the web section. 3.5
looses the QUERY object with it's contents moved to CLASSes. This was done to limit
the number of expressions that potentially needed evaluation and made code a bit
simpler.
So, to fix, move your TEMPLATE line into the CLASS object and remove the QUERY object.
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Wolfgang W. Wasserburger" <wasserburger at plan.at> 08/28/01 06:14AM >>>
Teb,
the Header and Footer ahs to be transfered to the Web-Section of teh mapfile
and it will work.
Greetings from sunny Vienna, Austria
WWW: http://www.plan.at/ - http://www.punktgenau.at/ -
http://www.plan.at/home/mitarbeiter/wwa/
-----Original Message-----
[mailto:owner-mapserver-users at lists.gis.umn.edu]On Behalf Of teb
Sent: Wednesday, August 22, 2001 5:36 PM
To: mapserver-users at lists.gis.umn.edu
Cc: robbrown99 at hotmail.com
Subject: [mapserver-users] Simple QUERY problem (fwd)
Hello all,
I am trying to get a simple query to work using v3.5 and the Mapplet. I
have used the QUERY command in the map file and have created a template,
header and footer. However, when I initialise the map from the form I get
the following message:
loadLayer(): Unknown identifier. (QUERY):(451)
I commented out the query commands in the map file and the map then
worked, but of course no query capability!
Does anyone know where I might have gone wrong? Part of my map file looks
like this:
LAYER
NAME "PROW_Nodes"
TYPE POINT
DATA PROW_Link_point
LABELITEM "REF_NO"
STATUS OFF
CLASS
COLOR 255 51 0
NAME "Public Right of Way Nodes (Queryable)"
SYMBOL "signpost"
LABEL
SIZE SMALL
COLOR 0 0 0
BACKGROUNDCOLOR -1 -1 -1
OUTLINECOLOR 255 255 255
POSITION AUTO
TYPE BITMAP
BUFFER 2
END
! ! ! ; END
HEADER "PROW_Node_header.html"
FOOTER "PROW_Node_footer.html"
QUERY
TEMPLATE "PROW_Node_template.html"
END
END
I would be grateful for any suggestions. Thanks for your time.
Regards,
Rob
Get your FREE download of MSN Explorer at http://explorer.msn.com
