Compiling MapServer on SuSE 7.0
    Nicol Hermann
    nicol at online.de
    Sun Jan  7 11:37:26 PST 2001
Dear List,
I´m trying to compile MapServer with php support on suse 7.0.
I have configured php 4.0.4 with the following Options.
'./configure' '--with-mysql' '--with-apache=/home/nicol/programme/apache_1.3.14'
'--with-xml' '--enable-track-vars' '--with-gd=/home/nicol/programme/gd-1.8.3' '--with-zib'
'--with-ttf' '--mandir' '--with-packages' '--with-ftp' '--with-jpeg-dir' '--with-xpm-dir'
'--enable-bcmath' '--with-system-regex'
In the next step i run the configuration Script from mapserver with the latest sources from cvs (07.01.2001) with the following parameters
./configure --prefix=/usr/local/mapserver --with-gd=/home/nicol/programme/gd-1.8.3
 --with-tiff --with-jpeg --with-eppl --without-ttf  --with-php=/home/nicol/programme/php-4.0.4 --with-apache=/usr/local/httpd
This proceedure finshed without any errors. Whenever i run the make script it crashes with the message below
yacc -p msyy -d -omapparser.c mapparser.y
usage: yacc [-dlrtv] [-b file_prefix] [-p symbol_prefix] filename
make: *** [mapparser.c] Error 1
I´ve no idea which problem causes that error. Does anybody out there has the same problem and could give me a hint to this newbie problem?
yacc is installed and working fine.
Thanks a lot
Nicol
Powered by http://www.einsundeins.com/
More information about the MapServer-users
