Ross Searle's ArcView Interface
Ross.Searle at dnr.qld.gov.au
Sun Jan 14 19:38:20 EST 2001
Alex,
I'm thinking that your problem is that you might be using the png version of
the mapserver executable. The java applet doesn't support the png image
format so download the gif version of the exe and see how you go. Otherwise
it is most likely a path problem. You can check if mapserver is actually
creating the images in the temporary directory that you have specified.
I am currently finishing off a new version of the utility. The old one
wasn't really set up to deal with WinTel environments. I just need a few
people to help in the testing. Any volunteers.
Ross
-----Original Message-----
[mailto:Alexspringer at lists.gis.umn.edu]
Sent: Saturday, 13 January 2001 7:50
To: mapserver-users at lists.gis.umn.edu
Subject: Ross Searle's ArcView Interface
We are attempting to implement Ross Searle's ArcView interface to MapServer
using an ordinary NT4 server setup.
We cannot get the interface to work. The appropriate image never appears.
The problem is thought to be a simple setting or path but all the options
attempted have tried have not worked.
Has anyone been successful with this that might be able to help us get the
settings correct? What might be most helpful is list of the "mapserver
default file settings" along with corresponding hard drive folder
equivalencies.
Thank you.
Alex
The information in this e-mail together with any attachments is
intended only for the person or entity to which it is addressed
and may contain confidential and/or privileged material.
Any form of review, disclosure, modification, distribution
and/or publication of this e-mail message is prohibited.
If you have received this message in error, you are asked to
inform the sender as quickly as possible and delete this message
and any copies of this message from your computer and/or your
computer system network.
