Part 3 of the AIX problems (fwd)
teb at mallit.fr.umn.edu
Thu Jan 18 09:46:01 EST 2001
Forwarded message:
> From peter.jacobs at ah21sn06.kpnhs.nl Thu Jan 18 08:02:17 2001
> From: "Peter H.M. Jacobs" <peter.jacobs at ah21sn06.kpnhs.nl>
> Reply-To: peter.jacobs at ah21sn06.kpnhs.nl
> Organization: Javel b.v.
> Date: Thu, 18 Jan 2001 15:08:47 -0800
> X-Mailer: KMail [version 1.1.99]
> Content-Type: text/plain;
> charset="iso-8859-1"
> To: mapserver-info at lists.gis.umn.edu
> Subject: Part 3 of the AIX problems
> MIME-Version: 1.0
> Message-Id: <01011815084702.01857 at peter>
> Content-Transfer-Encoding: 8bit
> Content-Length: 858
> Dear Daniel and others,
> I've done excactly as you stated and experienced just the error as you
> mentioned.
> First I installed the GNU-make. This indeed does not give any problems
> concerning the standard Makefile. Everything compiled just fine after I
> declared the Path to the perl directory where perl.exp is located. It seems
> to result in the same php_mapscript.so file as with the AIX make (about
> 140kB)
> I still get the message (it does not seem to be a php library) so as you
> stated I called nm ./php_mapscript.so |grep get_modules . This method does
> not seem to be there.
> I tried to change the Makefile and added -DCOMPILE_DL=1 statement to CC (it
> was already declared in the CFLAGS). As expected this dit not solve the
> problem.
> Do you have any idea how I could get mapscript working or where I could check
> the the .c files
> Regards
> Peter
