query result map
Yeewen Sat
yeewen at petromap.com
Thu Jan 25 16:18:12 EST 2001
I've implemented something similar to Case #3 in
http://maps.dnr.state.mn.us/mapserver_demos/tests/itemquery/test.html
but the user query by dragging a box with the mouse over a map to query
objects. I display a query result and result map in a popup window.
Anyway, I noticed this behaviour:
If I set the STATUS of the layer I'm querying on to be OFF, the result map
doesn't show up. If STATUS is set to DEFAULT, the result map shows up.
My problem is that I have to set the LAYER STATUS to OFF in order to be able
to turn layer on and off.
Does anyone has any idea on how to resolve this problem? ie to get both
(query result map and layer on/off) to work?
Here's my mapfile, ywseis.map, showing only the layer that I query on.
# Start of layer definitions
LAYER
NAME ss1l
TYPE LINE
STATUS OFF
DATA ss1l
CLASSITEM 'ID'
MAXSCALE 3000000
CLASS
EXPRESSION /.*/
COLOR 230 0 0
SYMBOL 0
END
CLASS
EXPRESSION /xxx/
COLOR 0 0 255
END
QUERY
TEMPLATE "../www/lineinfo.html"
END
TOLERANCE 10
END
lineinfo.html
<font size+1><b>Layer: Seismic Lines</b></font><p>
<table cellpadding=5 cellspacing=2 border=0>
<tr
bgcolor=#CCCCCC><th>ID</th><th>SIZE</th><th>STYLE</th><th>COLOR</th><th>FILL
</th><th>PATTERN</th><th>ANGLE</th><th>TEXT</th><th>ATTR</th></tr>
<tr><td>[ID]</td><td>[SIZE]</td><td>[STYLE]</td><td>[COLOR]</td><td>[FILL]</
td><td>[PATTERN]</td><td>[ANGLE]</td><td>[TEXT]</td><td>[ATTR]</td></tr>
<td><img
src="/cgi-bin/mapserv?map=../map/ywseis.map&item=ID&value=[ID]&mode=itemquer
ymap&mapext=shapes" height="200" width="200"></td>
</table>
<p>
Yeewen
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20010125/2f534d64/attachment.html
