PHP - query expression
Robert Ofarrell
s371538 at student.uq.edu.au
Wed Jan 31 23:33:10 EST 2001
> There is a queryObj class with a setExpression() method that you should
> be able to use. However, I just realized that there is no way to access
> existing query objects inside a layer from MapScript... you can only
> create new ones. This seems to be true with the Perl MapScript too, is
> that possible, Steve?
> Hummm... I guess this part of the code hasn't been used much before...
> What you could do until this is resolved is not include a QUERY object
> in your layer in the .map file, and instead create one in your script
> using $query=ms_newQueryObj($layer); ... and then you should be able to
> use setExpression() on the new object.
I don't fully understand how this is going to work. How do I extract the
results from the newly created query?
Robert O'Farrell
University of Queensland, Brisbane, Australia
