[mapserver-users] PHP/Mapscript module and Phorum
Daniel Morissette
morissette at dmsolutions.ca
Mon Jul 2 19:49:02 EDT 2001
Just as a follow-up, the query class is gone in MapServer 3.5, so this
issue applies only to PHP MapScript 3.3.011 and 3.4.
Daniel
Rob Martinson wrote:
> Just FYI for those of you that run Phorum PHP forums with mySQL (and
> possibly others). You cannot leave your php_mapscript.so loaded at all
> times with this or use it within the same script where phorum is called.
> And if you're running Apache as standalone instead of through inetd you
> will have additional issues. The problem is that Phorum declares a query
> class which conflicts with a class of the same name in the Mapscript
> module. What I have done is just gone through all of their code and
> renamed the class so it doesn't interfere.
> Rob Martinson
> Nichebox - http://www.nichebox.com
> Development - http://dev.nichebox.com
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
