[mapserver-users] Works in Winnt but not Linux...
Janet Ciavarelli
Jciavarelli at city.kamloops.bc.ca
Thu Jul 19 16:14:48 EDT 2001
I have a particular line in my html file that works fine in WinNT with Apache.
But this same line I cannot get to work in Linux running apache.
Here is the line:
<img border="1" src="/cgi-bin/mapserv?map=/ms_demo/example8.map&mode=map&layer=city_property&layer=pothole&layer=city_streets&imgext=$ar{imgext}&imgbox=$ar{imgbox}&imgxy=$ar{imgxy}">
I've tried modifying this line in several different ways. I've even tried creating an error in the example8.map file and seeing if at the very least it will choke on it. It doesn't even do that. It's like it's just not even executing the mapserv executable. Yet I know the mapserv executable works cause it is called properly on a "SUBMIT".
Any ideas why this line is not executing the mapserv command?
Janet.
