Fw: [mapserver-users] RE: To SCSI or not ?
Eric Frost
frost at cnsnet.com
Mon Jul 30 12:12:16 EDT 2001
The way I understand it, IDE uses a lot of CPU time if you have many
requests, SCSI uses next to none.. on one of our servers (file/print/
terminal) we have a 4-drive SCSI array and one 80 GB IDE drive for
temporary storage... when anyone transfers large amounts of data
to/from the IDE drive, the terminal services sessions start to hang--
and this is a dual-CPU machine.
Anyway, SCSI just does better for servers.. but can definitely eat up
your budget. You could start with the IDE drive--it will work--, then
depending on how many hits you eventually get, the IDE machine
may need to be replaced with a faster machine sooner than if you
started with a SCSI drive...
Eric
----- Original Message -----
To: nyon ; mapserver-users at lists.gis.umn.edu
Sent: Monday, July 30, 2001 8:21 AM
Subject: Re: [mapserver-users] RE: To SCSI or not ?
Yes,
With SCSI more then 1 application can access your hard drive at a time.
With IDE, only 1 aplpication can access your hard drive at a time.
So If you go with SCSI, then if you have 10 people request a map from your mapserver, then each persons request wont have to waite for the previous request to finish( on the hard drive).
If you plan on getting a ton of hits( people using your site), got with SCSI.
-jim
To: mapserver-users at lists.gis.umn.edu
Sent: Sunday, July 29, 2001 10:49 PM
Subject: [mapserver-users] RE: To SCSI or not ?
I am setting up my map server on a shoestring budget and was
wondering whether a SCSI hardisk makes a big difference compared to a IDE- 7200rpm hd for
serving maps.
thanks
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20010730/641271cb/attachment.html
