Copyright notice at the lower left of the map image
    Chad Streck
    chads at adci.com
    Wed Mar  7 13:07:49 PST 2001
New to Mapserver, but enjoying every bit!  Started late last week.
I saw the short thread on copyrights on an image and saw the mapfile
layer definition that added the copyright, but I was wondering if there
is a way of doing the same/similar thing in mapscript.  I have been
using PHP/Mapscript and a part of the app I'm writing includes changing
the size of the map window, so I don't have static values to put the
copyright in the lower right corner.  I need to be able to move it to
the extent of my map window.
I tried using PHP to create something similar to the map file
definition, but am unable to get anything to show, or add the text to a
shapeobj.  Here is what I have so far...
// add copyright
function copyright($mapobj, $author, $txtwidth=50, $txtheight=10) {
       $layer = ms_newlayerobj($mapobj);
// add copyright
       // base properties
       $layer->set('name', 'credits');
       $layer->set('status', 'default');
       $layer->set('transform', 'false');
       $layer->set('type', 'annotation');
       $layer->set('labe', 'annotation');
       // point feature with text for location
       $point = ms_newpointobj();
       $point->setXY($mapobj->width - $txtwidth, $mapobj->height -
$txtheight);
       $line = ms_newlineobj();
       $line->add($point);
       $shape = ms_newshapeobj($layer);
       $shape->add($line);
                                       // make year computed
       //$shape->set('text', "© 2001 $author");
//int draw(mapObj map, layerObj layer, imageObj img,
//            string class_name, string text)
       $layer->addfeature($shape);
       // class for display
       //$layer->set('',);
//LAYER
//        NAME "credits"
//        STATUS DEFAULT
//        TRANSFORM FALSE
//        TYPE ANNOTATION
//        FEATURE
//                POINTS 4 369 END
//                TEXT '© 2001 ADCi'
//        END
//        CLASS
//                LABEL
//                        TYPE TRUETYPE
//                        FONT helv
//                        SIZE 8
//                        ANTIALIAS
//                        COLOR 0 0 255
//                        OUTLINECOLOR 255 255 255
//                        POSITION UR
//                END
//        END
//END
This does have extraneous comments while I am trying to get it to work,
and I do know it doesn't work for me, so any help would be appreciated.
Thanks,
Chad
More information about the MapServer-users
