dbase-php Random corruption
Chad Streck
chads at adci.com
Fri Mar 9 14:32:25 EST 2001
I am now starting to work with queries, but it seems that for the
attribute data from the dbf, I'm getting random information. I can
click on the same object in my map, and get completely different results
from the dbf, while the shape object has the same information. So I
know that the click and the query are working, but not the dbf.
Any help would be appreciated.
tia,
chad
Sample Code:
for($loop = 0; $loop < $query->numresults; $loop++) {
$shape = $query->next();
// open db if not opened
if(($db == 0) || ($oldlayer != $shape->layer)) {
@dbase_close($db);
$layer = $mapobj->getlayer($shape->layer);
//print "$mapobj->shapepath/$layer->data.dbf";
$db =
dbase_open($mapobj->shapepath."/".$layer->data.".dbf", 0);
$index = $shape->shape + 1;
// PHP dies when I try to execute dbase_get_record_with_names
// $rec = dbase_get_record_with_names($db, $shape->shape + 1);
$rec = dbase_get_record($db, $shape->shape + 1);
foreach($rec as $value) {
print "<br>$value";
$oldlayer = $shape->layer;
@dbase_close($db);
Map Layer Definition:
class
color 225 225 225
name "Counties"
outlinecolor 150 150 150
label
antialias
buffer 3
color 255 32 255
font "helv"
mindistance 100
minfeaturesize 90
position cc
size 10
type TRUETYPE
end
end
queryitem "polygon_nm"
tolerance 0
query
expression /./
template ""
end
end
System:
Linux Mandrake 7.2
PHP 4.04pl1 - ./configure --with-apxs=/usr/sbin/apxs --without-mysql
--with-system-regex --with-dbase
Mapserver 3.4 - ./configure --with-apxs=/usr/sbin/apxs
--with-php=../../php-4.0.4pl1 --with-freetype --with-proj
