Querying capabilities
    Kieran J. Ames
    kames at keyspanenergy.com
    Fri Mar 16 13:31:09 PST 2001
Thanks!
The Burnett site is very nice... well thought out (with the exception of the "Simple HTML
Based System" experiencing some problems). <wink>
Is the Java interface available? Is it documented?
Anyway, thanks for the guidance.
Kieran
Stephen Lime wrote:
> Sure, you can restrict queries to a single layer using the form parameter "qlayer". You'd
> do this with a radio button so only a single layer would be active at any one time. I
> believe the Burnett Catchment system demonstates this.
> http://www.dnr.qld.gov.au/resourcenet/land/lris/webgis/burnett/
> Steve
> Stephen Lime
> Internet Applications Analyst
> Minnesota DNR
> 500 Lafayette Road
> St. Paul, MN 55155
> 651-297-2937
> >>> "Kieran J. Ames" <kames at keyspanenergy.com> 03/16/01 02:07PM >>>
> Hello list. I'd like to ask a question about querying.
> Does Mapserver support this...?
> I have several layers rendered via the map file: Points, lines,
> polygons, more lines, more points, etc. I only have one of them defined
> as being queried.
> Can I define several (with different query templates) and let the user
> select which he/she wants to view details on? If so, any examples out
> there?
> Thanks for all your help.
> Kieran
More information about the MapServer-users
