Retrieving map image via URL
Ma
marin at here.is
Thu Mar 22 18:08:28 EST 2001
and where in this example is the gif file and how to get it with wget?
another one?
Ma
Jaynika Barot wrote:
> http://localhost/mapserver/bin/mapserv.exe?mode=map&layer=layer1&imgext=3641
> 07.000000+3773595.000000+365719.000000+3774689.000000&map=c%3A%5CInetpub%5Cw
> wwroot%5Cms_demo%5Cdmpdemo.map
> -jaynika
> -----Original Message-----
> From: Ma [mailto:marin at here.is]
> Sent: Thursday, March 22, 2001 9:28 AM
> To: mapserver-users at lists.gis.umn.edu
> Subject: Re: Retrieving map image via URL
> one wget example how to get the gif file via URL ?
> Ma
> Stephen Lime wrote:
> > Sure. All you need to do is change the mapserver "mode" by adding
> &mode=map to the
> > URL. Remember the default mode is "browse" which returns HTML/URL
> (redirect).
> > Steve
> > Stephen Lime
> > Internet Applications Analyst
> > Minnesota DNR
> > 500 Lafayette Road
> > St. Paul, MN 55155
> > 651-297-2937
> > >>> Armin Burger <armin.burger at territoriumonline.com> 03/22/01 09:00AM >>>
> > I would like to retrieve the map image from a ms server only via its URL
> > using a program like wget or curl. When I'm using the normal parameter
> like
> > in the URL line of the browser I get the html document back. Can I define
> > the URL request this way that I will get back the gif image of the main
> map
> > with certain layers and a certain extend etc.?
> > Armin
> > Armin Burger
> > Territorium Online
> > Siemensstrasse/Via Siemens 19 - I-39100 Bozen/Bolzano - Italia
> > tel: +39-0471-568185 / fax: -- 568078
> > _
