AZ-C update...
Chad Streck
chads at adci.com
Wed Mar 28 09:54:06 PST 2001
Here is what I have so far, and customer points not showing......
When I run proj from the command line, I get this.....
[cas at saratoga cas]$ /usr/local/bin/proj +proj=tmerc -v +ellps=WGS84
+units=ft +lon_0=111w55 +lat_0=31w +x_0=699998.60 +y_0=0 +no_defs
#Transverse Mercator
# Cyl, Sph&Ell
# +proj=tmerc +ellps=WGS84 +units=ft +lon_0=111w55 +lat_0=31w +x_0=699998.60
# +y_0=0 +no_defs
The values I got using Mentor software.
My mapfile has these values....
projection
"proj=tmerc"
"ellps=WGS84"
"units=ft"
"lon_0=111w55"
"lat_0=31w"
"x_0=699998.60"
"y_0=0"
"no_defs"
end
...and for the customer layer....
layer
classitem "status"
# maxscale 1000000
# minscale 0
name "ace"
data "procon/ace-cust"
status default
type point
projection
geographic
end
class
color 0 64 128
expression /A/
name "Existing Customers"
size 8
symbol "hospital"
end
class
color 128 64 0
expression /B/
name "New Prospects"
size 8
symbol "hospital"
end
class
color 64 128 0
expression /C/
name "New Customers"
size 8
symbol "hospital"
end
queryitem "ddlong"
tolerance 5
query
expression /./
template ""
end
end
Hope this gives you an idea of where I'm at.
Thanks,
Chad
More information about the MapServer-users
