[mapserver-users] other problems from 3.4 to 3.5 ?
Stephen Lime
steve.lime at dnr.state.mn.us
Mon May 7 11:15:12 EDT 2001
QUERY objects are gone and their contents have been moved into CLASS
objects. Names of the fields have stayed the same HEADER, FOOTER and
TEMPLATE. JOINs will also live there but have not been implemented in 3.5
yet. With QUERY gone QUERYITEM is no longer needed.
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "A. Giacomelli" <andreag at crs4.it> 05/07/01 08:30AM >>>
Dear Stephen,
thanks for your previous reply on the addition of the METADATA tag.
Having fixed this, from the 3.5 setup, I am getting other complaints
from the mapserver, related to other tags in the map file (QUERY,
QUERYITEM, HEADER...), always as a loadLayer error.
plus another strange error reading a shapefile (which works clean on my
first installation)...
I have tried searching the mailing list archive for references to
documentation to the 3.5 map files, without success (maybe I tried with
the wrong search keys, or it's not there yet).
Would you confirm that even the errors on QUERY, QUERYITEM etc. come
from new map file definitions ?
(in this case I think I'll stick to 3.4 also in the second server I am
setting up...)
Thank you and regards,
Andrea Giacomelli
Centre for Advanced Studies, Research and
Development in Sardinia
Environment Group
http://www.crs4.it/~andreag
