[mapserver-users] VisualC++ Experts..
Eduin Yesid Carrillo
yecarrillo at hotmail.com
Thu May 17 13:16:52 EDT 2001
Hi list.
Please give me any hint for this error in vc6 and mapsde.c. Micosoft
Knowledge Base give some workarounds for this error, but I don't know how
implement them for sg.h (ArcSDE).
All 26 times that mapsde.c call SDE functions, generates this error:
Creating library mapserv.lib and object mapserv.exp
mapserver.lib(mapsde.obj) : error LNK2001: unresolved external symbol
_SE_connection_free
_SE_shape_free
_SE_shape_get_num_parts
mapserv.exe : fatal error LNK1120: 26 unresolved externals
NMAKE : fatal error U1077: '"C:\Archivos de programa\Microsoft Visual
Studio\VC98\BIN\link.exe"' : return code '0x460'
Stop.
Error executing NMAKE.
>From Microsoft:
http://support.microsoft.com/support/kb/articles/Q123/7/68.asp?LN=EN-US&SD=gn&FR=0&qry=unresolved%20external%20symbol&rnk=6&src=DHCS_MSPSS_gn_SRCH&SPR=VCC
CAUSE
Inline functions are not visible outside of the source file where they are
defined. The Inline Specifier section in the C++ Language Reference states,
"Functions that are declared as inline and that are not class member
functions have internal linkage unless otherwise specified."
RESOLUTION
Here are five possible workarounds:
**Declare the inline function with the extern keyword to force external
linkage. Note, however, that using extern with class member functions will
cause a warning with /Ze, and an error with /Za.
-or-
**Move the function definition to the header file so it's included in each
translation unit used.
-or-
**Remove the inline specification.
-or-
**Force a function version of the inline function to be created in the
module that it is defined in. You can do this by referencing the address of
the inline function, by assigning it to a function pointer, or by passing it
to a function.
-or-
**Remove the /Ob1 (Only Inline) or /Ob2 (Any suitable) option from the
command line and compile with /Ob0 (Disable). The /Ob0 option is the default
if no options are specified.
STATUS
This behavior is by design.
Thanks in advanced.
_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
