[mapserver-users] Mapscript - Adding shape to shapefile
Daniel Morissette
morissette at dmsolutions.ca
Wed May 23 17:52:46 EDT 2001
Janet Ciavarelli wrote:
> Hi,
> I am have a script where I create a point and then try to add the point to a shapefile. I keep getting the following error on the 'add' method for the shapefile Obj. Does anyone see what's wrong with my 'add' method in the code below?
Janet,
In MapScript, a shapeObj constituted of 1 or more lineObj, which are in
turn constituted of a number of pointObj. So I think that to solve your
problem you need to add your point into a lineObj, and then add the
lineObj into the shapeObj ... and then pass the shape to the
shapefileObj->add method... i.e. try this:
$shapefile = new shapefileObj('potholes',$mapscript::MS_SHP_POINT);
$point = new pointObj();
$point->{x} = $ar{mapx};
$point->{y} = $ar{mapy};
$line = new lineObj;
$line->add($point);
$shape = new shapeObj($mapscript::MS_SHP_POINT);
$shape->add($line);
$shapefile->add($shape);
$shapefile = '';
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
