[mapserver-users] displaying bitmaps generated directly via CGI: problems porting app.
A. Giacomelli
andreag at crs4.it
Mon May 28 09:10:03 EDT 2001
I have an application running on an NT box where static images are
generated directly via calls to the mapserv executable. It works fine.
I have moved the installation to another machine (changing a few
directories, and -of course- updating any relevant dirs. in my code),
and the IMG is no longer displayed.
in the original app. the image was generated with something like:
/cgi-bin/mapserv?map=..\htdocs\mia\gmap3\htdocs\cat.map&mapext=1432280.22+4480118.85+1452280.22+4500118.85&mapsize=100+100&mode=map
in the new version, for logistic reasons I have moved my apache htdocs
dir out of the Apache tree, so now it looks like:
/cgi-bin/mapserv?map=C:\something\htdocs\mia\gmap3\htdocs\cat.map&mapext=1432280.22+4480118.85+1452280.22+4500118.85&mapsize=100+100&mode=map
Mapserv CGI reference states that the path specified in the map=
parameter should be relative to the location of the executable;
however, I have noted that absolute paths are also accepted (so my
*second* example works on the *first* installation.
The only difference I can see is that in my new installation data and
apache reside currently on two different drives. Do you think I should
move the data to the same drive as Apache ?
(...can the problem be due to something hard-coded in the Windows binary
Thanks for any advice
Andrea Giacomelli
Centre for Advanced Studies, Research and
Development in Sardinia
Environment Group
http://www.crs4.it/~andreag
