[mapserver-users] PHP4 load library error
Daniel Morissette
morissette at dmsolutions.ca
Wed May 30 14:52:35 EDT 2001
Janet Ciavarelli wrote:
> I followed all the instructions for loading the php_mapscript.dll but get this error when I run phpinfo_mapscript.php4
> Warning: Unable to load dynamic library './php_mapscript.dll' - The specified module could not be found. in g:\apache1319\apache\htdocs\phpinfo_mapscript.php4 on line 17
> I'm wondering if there's another variable I have to set in the httpd.conf file to tell it where to look for it, cause it's looking for it in the wrong place.
The location of the PHP extensions (DLLs) is set in the php.ini file
that you should have copied in your C:\windows directory.
Look for the following line in php.ini:
extension_dir = c:/apache/php4/extensions ; directory in which the
loadable extensions (modules) reside
... and replace C:/apache/php4/extensions with whatever the location of
your php4 extensions directory is, and then copy your php_mapscript.dll
to that directory.
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
