[mapserver-users] Add points to a online map? (FWD)
Twan Kogels
twan at twansoft.com
Thu Nov 1 03:55:51 EST 2001
Goodmorning,
First sorry for the email i sended to the wrong email address, thanks goto
Ted for forwarding it to the right address.
I don't know if this list is also ment for thanks replies, but wanted to
thank Searle and Paul for the clear answers.
I've just looked into the mapscript documentation and it seem relative
easy, so im gonna try it!
- twan
At 09:39 31-10-2001 -0800, you wrote:
>Yes. You might find one way to do this is to use PostGIS to store the
>point layer. Jeff is actually putting together a little
>Mapserver/PostGIS app right now to do exactly this. All the background
>layers are shape files, but the point layer is a db layer, so it is very
>easy to add new points to it and edit it. Needless to say, mapscript
>coding is definately required. You could also do this using a shape file
>to store the points, but could have file integrity problems if you were
>ever unlucky enough to get two concurrent edits of the file.
>teb wrote:
> > Is it possible that a visitor of our website adds a point to our online map
> > and also add specific information about the point? Will this change (adding
> > a point) be directly visible on the map?
> __
> | Paul Ramsey
> | Refractions Research
> | Email: pramsey at refractions.net
> | Phone: (250) 885-0632
> \_
http://www.twansoft.com
