[mapserver-users] Hardware advice?
Flavio Hendry
flavio at tydac.ch
Tue Nov 6 03:02:37 PST 2001
Hi Twan
>I'm planning to use MapServer and PostGIS for a demonstration project. At
>the current time i'm planning the hardware requirements of this project.
>Can anybody tell me if there are any minimum hardware requirements? The
>map
We use a 1GHz, 256 RAM IBM Netfinity with RAID controller (RAID 5 configuration).
If you have large datasets I'd definitely suggets a RAID and fast Harddisks, it's worth it (our experiance is that processor and RAM do not bring that much of a difference, RAID however a lot).
>I'm planning to purchase the linux distribution Suse, will MapServer
>compile and run on this distribution?
We have SUSE 7.2 - no problem. With the above hardware it's as fast as a Ferrari ...
ciao
flavio
******** 10 Years TYDAC Event - Review see www.tydac.ch *********
xxxxxxxxxxxxxxxxxxx ATTENTION: New Address xxxxxxxxxxxxxxxxxxxxx
############ Mit freundlichen Gruessen / Kind Regards
############ Flavio Hendry- mailto:flavio at tydac.ch
############ TYDAC AG - http://www.tydac.ch
#### #### Geographic Information Solutions
#### #### Luternauweg 12 -- CH-3006 Bern
############ Tel +41 (0)31 368 0180 - Fax +41 (0)31 368 1860
MAPINFO Strategic Partner - PCI Reseller - FME Distributor
ESRI ArcGIS Solution Provider
More information about the MapServer-users
