[mapserver-users] reference box in reference map
    Stephen Lime
    steve.lime at dnr.state.mn.us
    Thu Nov  8 07:09:20 PST 2001
You see the partial rect because that's the extent that is requested and part of it falls
outside of the reference map. The trick is making sure your reference map is large
enough (extent-wise) to handle whatever the default extent is.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Maul, Andreas-Alexander" <Andreas.Maul at bgr.de> 11/08/01 06:41AM >>>
Hi list,
why does mapserver draw initially the reference box in the reference map
only partially? In example 3 of the tutorial  the first call of the
reference map shows only the right side of the red rectangle. The whole
rectangle is drawn only after zooming in. I get the same behaviour in my
application. Is there a trick to render the complete rectangle before
zooming in?
Andreas Maul
More information about the MapServer-users
