How to create TEMPLATE dynamically under php
CATHIGNOL, Frederic
Frederic.CATHIGNOL at astrium-space.com
Fri Nov 9 06:32:39 PST 2001
Hello from France;
I certainly miss something, but I would like to transform this .MAP code in
PHP :
LAYER
NAME xx
METADATA
"DESCRIPTION" "xx"
"RESULT_FIELDS" "NAME"
END
TYPE POLYGON
STATUS OFF
DATA xx
CLASS
NAME "xx"
COLOR 200 255 0
OUTLINECOLOR 120 120 120
TEMPLATE "ttt_query.html"
END
TOLERANCE 5
END # Layer
I do not know how to create the TEMPLATE line. How do you do that ?
I tried the code here after, but I block on the template tag :
$layer = ms_newLayerObj($gpoMap);
$layer->set("name","xx");
$layer->set("type", MS_LAYER_POLYGON);
$layer->set("data", "xx");
$layer->set("status", MS_ON);
$layer->setMetaData("DESCRIPTION","xx");
$layer->setMetaData("RESULT_FIELDS","NAME");
$fredclass = ms_newClassObj($layer);
$fredclass->set("name","xx");
$fredclass->set("color",2);
$fredclass->set("outlinecolor",2);
Thanks Guys for your help to a french developper !
(frederic.cathignol at bigfoot.com)
Best regards,
F.CATHIGNOL
More information about the MapServer-users
