[mapserver-users] How to create TEMPLATE dynamically under php (fwd)
Daniel Morissette
morissette at dmsolutions.ca
Fri Nov 9 08:08:33 PST 2001
Frederic,
A simple call to $fredclass->set("template", "ttt_query.html"); should
work with MapServer 3.5 ... did you try that? If it didn't work then
wihch error did you get?
Daniel
> From: "CATHIGNOL, Frederic" <Frederic.CATHIGNOL at astrium-space.com>
> Hello from France;
> I certainly miss something, but I would like to transform this .MAP code in
> PHP :
> LAYER
> NAME xx
> METADATA
> "DESCRIPTION" "xx"
> "RESULT_FIELDS" "NAME"
> END
> TYPE POLYGON
> STATUS OFF
> DATA xx
> CLASS
> NAME "xx"
> COLOR 200 255 0
> OUTLINECOLOR 120 120 120
> TEMPLATE "ttt_query.html"
> END
> TOLERANCE 5
> END # Layer
> I do not know how to create the TEMPLATE line. How do you do that ?
> I tried the code here after, but I block on the template tag :
> $layer = ms_newLayerObj($gpoMap);
> $layer->set("name","xx");
> $layer->set("type", MS_LAYER_POLYGON);
> $layer->set("data", "xx");
> $layer->set("status", MS_ON);
> $layer->setMetaData("DESCRIPTION","xx");
> $layer->setMetaData("RESULT_FIELDS","NAME");
> $fredclass = ms_newClassObj($layer);
> $fredclass->set("name","xx");
> $fredclass->set("color",2);
> $fredclass->set("outlinecolor",2);
> Thanks Guys for your help to a french developper !
> (frederic.cathignol at bigfoot.com)
> Best regards,
> F.CATHIGNOL
More information about the MapServer-users
