[mapserver-users] Question on command: "Mapserv -v"
Daniel Morissette
morissette at dmsolutions.ca
Thu Nov 15 08:56:43 EST 2001
The "mapserv -v" switch was added only in MapServer 3.4. It was not
there in 3.3.x ... that's why you get this error.
Daniel
jtang at gmu.edu wrote:
> Lists,
> I met a problem with the mapserver 3.3 when trying using
> command "mapserv -v".
> scs 100% mapserv -v
> This script can only be used to decode form results and
> should be initiated as a CGI process via a httpd server.
> >From the web document "Raster Howto", it says that this command will
> return something as "mapserver version 3.5 OUTPUT=PNG OUTPUT=JPEG...."
> I got different answer. Is it because they are different version?
> Thank you.
> Jiang Tang
