[mapserver-users] Mapserver on Solaris
Andries J. Algera aalgera at ibama.gov.br
Fri Nov 16 09:14:18 PST 2001
Over the last couple of days I've been trying to install mapserver on
Solaris 2.6 Sparc. I found that I wasn't able to compile with gcc-3.0.1
and gcc-3.0.2. I got errors regarding 'gxx_personality_v0'. It seems it
has got something to do with c++ compiler.
Using gcc-2.95.3 this problem disappeared and I was able to compile the
mapserver binary. In order to compile the php_mapscript module I found
that I had to have installed the proj.4 software even using the
--without-proj option during configuration. I also found that I had to add
the option -shared to the LDFLAGS in the php_mapscript Makefile.
Hope this information is usefull.
Andries
Andries Algera
CSR - IBAMA
SAIN L4, Lote 4, Ed. IBAMA Sede
70800.200  Brasilia / DF
BRASIL
ph: +5561 316-1326
          316-1453
fax:+5561 223-7108
More information about the MapServer-users mailing list
