[mapserver-users] 3.5 nightly build / PostGIS 0.6.2 (fwd)
Paul Ramsey
pramsey at refractions.net
Mon Nov 19 18:57:05 EST 2001
There are changes in the handling of symbols from 3.4 to 3.5, and that
is probably what is causing problems. Just skip the demo files and start
with your own file. Do a simple one-layer shape mapfile, get that
working, then move on to adding stuff like PostGIS layers etc.
Paul
teb wrote:
> ------------- Begin Forwarded Message -------------
> To: mapserver-info at lists.gis.umn.edu
> Date: Mon, 19 Nov 2001 13:20:35 -0800
> From: "Luis Viveros" <ldviveros at lycos.com>
> Mime-Version: 1.0
> X-Sent-Mail: off
> X-Priority: 3
> Subject: 3.5 nightly build / PostGIS 0.6.2
> X-Sender-Ip: 200.193.164.79
> Content-Language: en
> Content-Transfer-Encoding: 7bit
> Hello,
> I've been trying for several days and in several positions to install this MapServer
> recipe into a Mandrake 8.0:
> 1 Mapserver 3.5 (nightly build!)
> 1 PostGIS 0.6.2
> 1 GD-1.8.4 headache
> optional
> 1 Mapscript/PHP4
> 1 GDAL-1.1.5/OGR
> 1 PROJ-4.4.4
> I read some Warmerdam's advices and other's complains. My last tentative was this.
> Trying to use the ms_demo, IT sends me back the next sentence:
> msLoadSymbolFile():Unknown identifier. (SHADESET):(0)
> Someone told me it could be a nightly build bug, but I've seen this since june in
> the mailing_list (specially about gd/png/zlib).
> I have 80.000 parcel polygons in PostGIS and i need to show them yesterday (in the
> morning).
> I've edited Makefile and gdft/Makefile too. Similar.
> regards,
> Luis Viveros
> [root at postgis mapserver]# ./configure --with-gd=/tmp/gd-1.8.4
> --with-ogr=/tmp/gdal-1.1.5/apps/gdal-config --with-gdal=/tmp/gdal-1.1.5
> --with-postgis=/usr/local/pgsql/bin/pg_config
> loading cache ./config.cache
> checking for gcc... (cached) gcc
> checking whether the C compiler (gcc ) works... yes
> checking whether the C compiler (gcc ) is a cross-compiler... no checking whether we
> are using
> GNU C... (cached) yes
> checking whether gcc accepts -g... (cached) yes
> checking for c++... (cached) c++
> checking whether the C++ compiler (c++ ) works... yes
> checking whether the C++ compiler (c++ ) is a cross-compiler... no checking whether
> we are
> using GNU C++... (cached) yes
> checking whether c++ accepts -g... (cached) yes
> checking for ranlib... (cached) ranlib
> checking for flex... (cached) flex
> checking for yywrap in -lfl... (cached) yes
> checking for bison... (cached) bison -y
> checking if compiler supports -R... (cached) no
> checking if compiler supports -Wl,-rpath,... (cached) yes
> checking for exp in -lm... (cached) yes
> checking how to run the C preprocessor... (cached) gcc -E
> checking for ANSI C header files... (cached) yes
> checking for strcasecmp... (cached) yes
> checking for strncasecmp... (cached) yes
> checking for strdup... (cached) yes
> checking whether we should include JPEG support...
> checking for jpeg_read_header in -ljpeg... no
> libjpeg not found. JPEG support not included, possibly needed for GD. checking which
> version of
> GD to use...
> using libgd from -L/tmp/gd-1.8.4 -lgd
> checking where FreeType is installed...
> checking for FT_Init_FreeType in -lfreetype... yes
> using libfreetype -lfreetype from system libs.
> ./configure: unset: `ac_cv_lib_z_z,zlibVersion': not a valid identifier checking
> where Zlib is
> installed...
> checking for zlibVersion in -lz... (cached) yes
> using libz from system libs.
> checking where PNG is installed...
> checking for png_init_io in -lpng... yes
> using libpng from system libs.
> checking for gdImageGif in -lc... no
> checking for gdImagePng in -lc... yes
> checking for gdImageJpeg in -lc... no
> checking for gdImageWBMP in -lc... yes
> checking for gdImageStringFT in -lc... yes
> checking for gdImageString16 in -lc... yes
> checking for gdImageGifPtr in -lc... no
> using GD ( -DUSE_GD_PNG -DUSE_GD_WBMP -DUSE_GD_FT) from /tmp/gd-1.8.4.
> checking whether we should include PDF support...
> checking for PDF_setlinewidth in -lpdf... no
> checking for PDF_setrgbcolor in -lpdf... no
> checking for PDF_moveto in -lpdf... no
> checking for PDF_curveto in -lpdf... no
> checking for PDF_show_xy in -lpdf... (cached) no
> libpdf not found... PDF support not included.
> checking whether we should include TIFF support...
> checking for TIFFOpen in -ltiff... no
> libtiff not found... TIFF support not included.
> checking whether we should include EPPL7 support...
> including EPPL7 support.
> checking whether we should include PROJ.4 support...
> PROJ.4 support not requested.
> checking whether we should include ESRI SDE support...
> ESRI SDE support not requested.
> checking whether we should compile in MPATROL support...
> MPATROL support not requested.
> checking whether we should include OGR support...
> checking for OGRRegisterAll in -lgdal.1.1... (cached) yes
> using OGR from system libs.
> checking if GDAL support requested... yes, user supplied gdal-config ./configure:
> /tmp/gdal-1.1.5: is a directory
> checking if PostGIS support requested... yes, user supplied pg_config checking if
> OracleSpatial
> support requested... no
> checking whether we should include WMS support...
> OGC WMS Compatibility not enabled (PROJ.4 is required for WMS). checking whether we
> should include WMS Client Connections support... OGC WMS Client Connections not
> enabled
> (PROJ.4 and libwww required). Compiling with -DIGNORE_MISSING_DATA.
> checking for PHP/MapScript module options...
> PHP/MapScript module not configured.
> creating ./config.status
> creating Makefile
> [root at postgis mapserver]# make
> gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_GD_PNG
> -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_OGR -DUSE_GDAL -DUSE_POSTGIS
> -I/tmp/gd-1.8.4 -I/tmp/gdal-1.1.5/port -I/tmp/gdal-1.1.5/core -I/tmp/gdal-1.1.5/ogr
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include mapbits.c -o mapbits.o
> gcc -c -O2
> -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_GD_PNG -DUSE_GD_WBMP
> -DUSE_GD_FT -DUSE_OGR -DUSE_GDAL -DUSE_POSTGIS -I/tmp/gd-1.8.4
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include maphash.c -o maphash.o
> gcc -c -O2
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include mapshape.c -o
> mapshape.o gcc -c -O2
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include mapxbase.c -o
> mapxbase.o gcc -c -O2
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include mapparser.c -o
> mapparser.o gcc -c
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include maplexer.c -o
> maplexer.o
> maplexer.c:3112: warning: `yyunput' defined but not used
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include maptree.c -o maptree.o
> gcc -c -O2
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include mapsearch.c -o
> mapsearch.o gcc -c
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include mapstring.c -o
> mapstring.o gcc -c -O2
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include mapsymbol.c -o
> mapsymbol.o gcc -c
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include mapfile.c -o mapfile.o
> gcc -c -O2
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include maplegend.c -o
> maplegend.o gcc -c
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include maputil.c -o maputil.o
> gcc -c -O2
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include mapscale.c -o
> mapscale.o gcc -c -O2
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include mapquery.c -o
> mapquery.o gcc -c -O2
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include maplabel.c -o
> maplabel.o gcc -c -O2
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include maperror.c -o
> maperror.o gcc -c -O2
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include mapprimitive.c -o
> mapprimitive.o
> mapprimitive.c:771: warning: `get_centroid' defined but not used gcc -c -O2 -Wall
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include mapproject.c -o
> mapproject.o
> mapproject.c:66: warning: `msProjectGrowRect' defined but not used gcc -c -O2 -Wall
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include mapraster.c -o
> mapraster.o
> mapraster.c:602: warning: `drawTIFF' defined but not used
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include mapsde.c -o mapsde.o
> c++ -c -O2
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include mapogr.cpp -o mapogr.o
> gcc -c -O2
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include mappostgis.c -o
> mappostgis.o gcc -c
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include maplayer.c -o
> maplayer.o gcc -c -O2
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include mapresample.c -o
> mapresample.omapresample.c:419: warning: `msInitApproxTransformer' defined but not
> used
> mapresample.c:436: warning: `msFreeApproxTransformer' defined but not used
> mapresample.c:447: warning: `msApproxTransformer' defined but not used
> mapresample.c:551:
> warning: `msTransformMapToSource' defined but not used gcc -c -O2 -Wall
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include mapwms.c -o mapwms.o
> gcc -c -O2
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include mapwmslayer.c -o
> mapwmslayer.ogcc
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include maporaclespatial.c -o
> maporaclespatial.o maporaclespatial.c:782:6: warning: no newline at end of file
> maporaclespatial.c:782:6: warning: no newline at end of file gcc -c -O2 -Wall
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include mapgml.c -o mapgml.o
> mapgml.c: In
> function `msGMLWriteQuery':
> mapgml.c:10: warning: unused variable `j'
> mapgml.c: In function `msGMLWriteShape':
> mapgml.c:105: warning: unused variable `j'
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include mapprojhack.c -o
> mapprojhack.omapprojhack.c: In function `ConvertProjUnitStringToMS':
> mapprojhack.c:67:
> warning: implicit declaration of function `strcmp' mapprojhack.c: At top level:
> mapprojhack.c:66: warning: `ConvertProjUnitStringToMS' defined but not used gcc -c
> -O2 -Wall
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include epplib.c -o epplib.o ar
> rc libmap.a
> mapbits.o maphash.o mapshape.o mapxbase.o mapparser.o maplexer.o maptree.o
> mapsearch.o
> mapstring.o mapsymbol.o mapfile.o maplegend.o maputil.o mapscale.o mapquery.o
> maplabel.o
> maperror.o mapprimitive.o mapproject.o mapraster.o mapsde.o mapogr.o mappostgis.o
> maplayer.o mapresample.o mapwms.o mapwmslayer.o maporaclespatial.o mapgml.o
> mapprojhack.o epplib.o ranlib libmap.a
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include shp2img.c -o shp2img.o
> gcc -O2
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include shp2img.o -L. -lmap
> -L/tmp/gd-1.8.4
> -lgd -lfreetype -lpng -lz -lfreetype -lpng -lz -L/tmp/gdal-1.1.5 -lgdal.1.1
> -L/usr/local/pgsql/lib -lpq
> -lm -o shp2img gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL
> -DUSE_GD_PNG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_OGR -DUSE_GDAL
> -DUSE_POSTGIS -I/tmp/gd-1.8.4 -I/tmp/gdal-1.1.5/port -I/tmp/gdal-1.1.5/core
> -I/tmp/gdal-1.1.5/ogr -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include
> legend.c -o
> legend.o gcc -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_GD_PNG
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include legend.o -L. -lmap
> -L/tmp/gd-1.8.4
> -lm -o legend gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_GD_PNG
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include mapserv.c -o mapserv.o
> gcc -c -O2
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include cgiutil.c -o cgiutil.o
> gcc -O2 -Wall
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include mapserv.o cgiutil.o -L.
> -lmap
> -L/tmp/gd-1.8.4 -lgd -lfreetype -lpng -lz -lfreetype -lpng -lz -L/tmp/gdal-1.1.5
> -lgdal.1.1
> -L/usr/local/pgsql/lib -lpq -lm -o mapserv gcc -c -O2 -Wall -DIGNORE_MISSING_DATA
> -DUSE_EPPL -DUSE_GD_PNG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_OGR
> -DUSE_GDAL -DUSE_POSTGIS -I/tmp/gd-1.8.4 -I/tmp/gdal-1.1.5/port
> shptree.c -o
> shptree.o shptree.c: In function `main':
> shptree.c:40: warning: `byte_order' might be used uninitialized in this functiongcc
> -O2 -Wall
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include shptree.o -L. -lmap
> -L/tmp/gd-1.8.4
> -lm -o shptree gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL
> shptreevis.c -o
> shptreevis.o shptreevis.c: In function `main':
> shptreevis.c:76: warning: unused variable `pabyBuf'
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include shptreevis.o -L. -lmap
> -lgdal.1.1
> -L/usr/local/pgsql/lib -lpq -lm -o shptreevis gcc -c -O2 -Wall -DIGNORE_MISSING_DATA
> shptreetst.c -o
> shptreetst.o shptreetst.c: In function `main':
> shptreetst.c:68: warning: `node' might be used uninitialized in this function gcc
> -O2 -Wall
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include shptreetst.o -L. -lmap
> -L/tmp/gd-1.8.4
> -lm -o shptreetst gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL
> scalebar.c -o
> scalebar.o gcc -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_GD_PNG
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include scalebar.o -L. -lmap
> -L/tmp/gd-1.8.4
> -lm -o scalebar gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL
> sortshp.c -o
> sortshp.o gcc -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_GD_PNG
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include sortshp.o -L. -lmap
> -L/tmp/gd-1.8.4
> -lm -o sortshp touch perlvars
> pwd > perlvars
> echo -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_GD_PNG -DUSE_GD_WBMP
> -DUSE_GD_FT -DUSE_OGR -DUSE_GDAL >> perlvars echo -I. -I/tmp/gd-1.8.4
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts >> perlvars echo -L. -lmap -L/tmp/gd-1.8.4 -lgd
> -lfreetype
> -lpng -lz -lfreetype -lpng -lz -L/tmp/gdal-1.1.5 -lgdal.1.1 -L/usr/local/pgsql/lib
> -lpq -lm >>
> perlvars echo >> perlvars
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include tile4ms.c -o tile4ms.o
> gcc -O2 -Wall
> -I/tmp/gdal-1.1.5/ogr/ogrsf_frmts -I/usr/local/pgsql/include tile4ms.o -L. -lmap
> -L/tmp/gd-1.8.4
> -lm -o tile4ms
> [root at postgis mapserver]# make install
> cp -f libmap.a /usr/local/lib/
> cp -f map.h /usr/local/include/mapserver-3.5/
> ------------- End Forwarded Message -------------
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
