[mapserver-users] QUERYONLY?
Doyon, Jean-Francois
Jean-Francois.Doyon at ccrs.nrcan.gc.ca
Wed Nov 21 15:10:14 EST 2001
Hello,
I've updated the docs with this correction,
Cheers,
J.F.
-----Original Message-----
From: Stephen Lime [mailto:steve.lime at dnr.state.mn.us]
Sent: Monday, November 19, 2001 2:47 PM
To: Regina.Obe.PFD at ci.boston.ma.us; v at w.cl
Cc: mapserver-users at lists.gis.umn.edu
Subject: RE: [mapserver-users] QUERYONLY?
My bad, it's acually TYPE QUERY. How the query is handled is dependant on
the underlying shape type not the LAYER TYPE so that setting was moved. The
3.5 docs are mostly correct except that QUERYONLY should be QUERY.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Obe, Regina DND\MIS" <Regina.Obe.PFD at ci.boston.ma.us> 11/14/01
04:27PM >>>
I got a similar error too (not sure if these two are related) - using the
mapserv35_png_ogr for win32 build 11/7/2001. This was using the itasca demo
app for 3.5 (I downloaded 10/17/2001) (and my other apps which worked with
prior version of the mapserv 3.5 exe also give similar behavior. So I was
wondering if an interim change to specs had taken place during the 3.5
between 10/19 and now.
The prior version I was using was a build around 10/19/2001.
I get an error
getSymbol(): Symbol definition error. (END):(96)
(I did modify it a bit to work with my configuration so not the exact demo -
but just minor changes to paths)
When trying to use the itasca demo app - dated around 10/17/2001
Sent: Wednesday, November 14, 2001 11:29 AM
To: steve.lime at dnr.state.mn.us
Subject: Re: [mapserver-users] QUERYONLY?
> It's STATUS QUERY, not QUERYONLY.
also tried that, but:
Warning: MapServer Error in getSymbol(): (QUERY):(64)
LAYER
NAME buses
METADATA
"DESCRIPTON" "Rec Buses"
"RESULT_FIELDS" "ROUTE_ID"
END <---------------------------------------- Line 64
STATUS QUERY
TYPE LINE
LABELITEM "NOMBRE"
DATA r_bus_utm56
CLASS
NAME "Rec Buses"
TEMPLATE "test_draw_map.phtml"
LABEL
COLOR 238 238 140
FONT arial_V
TYPE truetype
ANGLE AUTO
ANTIALIAS
SIZE 7
END
COLOR 200 150 54
END
TOLERANCE 10
END
V. <v at w.cl>
